No start
No start
Postby 12vsmoker » Thu Sep 20, 2012 3:43 pm
i was driving after picking up my girl and the struck just stopped running i didnt even notice it for a second then tried to restart in neutral while rolling an nothing happened. i pulled over to see what the problem was and cant find anything.. it wont even attempt to start and everything else electrical works all lights an gauges power mirrors windows and lock. i cant figure it out. i would appreciate if anyone could give me some advice. thanks in advance!
12vsmoker
Re: No start
Postby ellis93 » Thu Sep 20, 2012 3:49 pm
If it turns over but won't light off check the fuel shutdown solenoid. Have somebody turn the key with your finger touchin the body of the solenoid and you should feel it click on.
Re: No start
Postby 12vsmoker » Fri Sep 21, 2012 8:17 am
nothing happens when i turn the key. i jumped the starter and got it to crank but no bang.also the gauges an radio dont work either dont know how thats related though. im just at a loss
12vsmoker
Re: No start
Postby 12vsmoker » Fri Sep 21, 2012 8:27 am
is there another fuse box other than the one by the break pedal? or distribution box? also where is the starter relay? sorry for the dumb questions im new to first gen.s
12vsmoker
Re: No start
Postby ellis93 » Fri Sep 21, 2012 9:27 am
12vsmoker wrote:is there another fuse box other than the one by the break pedal? or distribution box? also where is the starter relay? sorry for the dumb questions im new to first gen.s
Sorta.......there's this located on the driver fender well
Fuse links,pull on them to check to see if their bad
