HID Conversion?
HID Conversion?
Postby 93DodgeCummins » Thu Oct 11, 2012 6:13 pm
Has anyone done a HID conversion? I was looking for something that has a good light cut off so i don't blind people. I drive at night a lot and the old halogens just aren't enough for me.
I was thinking about something like this kit here : http://www.ebay.com/itm/7X6-SQUARE-PROJ ... 8d&vxp=mtr
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Re: HID Conversion?
Postby BC847 » Thu Oct 11, 2012 8:26 pm
I have no experience with the HIDs but must ask, have you considered the relay mod of the stock/OEM headlights?
It basically involves installing a couple of relays. They are wired such that the truck's headlight switch actually powers the relays. They in turn provide power directly to the headlights. In doing so, you're effectively removing all the dinky stock/OEM power conductors from the circuit allowing full 12 ~ 14vdc to the headlights. Further, with the addition of a single/simple diode, one can have both the low AND high bulbs illuminate when turning on the high-beams.
- Be sure to enlarge the headlight ground (common) conductors for each bulb as they are surprisingly small.
- Be sure to enlarge the stock/OEM body (truck) ground from the battery to the radiator support. It's dinky too.
Hope this helps. :)
Re: HID Conversion?
Postby 93DodgeCummins » Thu Oct 11, 2012 9:30 pm
Would you happen to have some comparison pictures between the brightness of the stock and upgraded wiring. I am just curious how much better it actually is.
93DodgeCummins
Re: HID Conversion?
Postby BILTIT » Fri Oct 12, 2012 5:48 am
I have HID's. I used autopal E-spec h4 conversion lenses and 3b 6000k hid lights.
Derek B.
BILTIT
Re: HID Conversion?
Postby 93DodgeCummins » Fri Oct 12, 2012 7:44 am
How do you like them? Do you have any pictures of the brightness? Do they have a good light cutoff?
93DodgeCummins
Re: HID Conversion?
Postby BILTIT » Fri Oct 12, 2012 8:25 am
I like them, they are miles ahead of stock lights. I may try the new LED's though, just curious.
The E-spec lens is supposed to be alot better for not brighting oncoming traffic. I don't think i have had anyone bright me yet in 2 years, i have had a few cars in front of me tap the brake lights though when i am following them. It is pretty common with trucks behind cars though, that's why the have a 2 position rearview mirror.
I will try and get some pics this weekend.
Derek B.
BILTIT
Re: HID Conversion?
Postby CUMMINSDODGEMAN3 » Tue Oct 23, 2012 11:04 am
I've got HIDs in my trucks as well, i'll never go back to a regular light!
Team Green's old hauler 05 3500 CTD 4x4 6sp 8in rize industries lift, 37 Toyo M/T's, Smarty, Edge Att, AFE intake, ATS manifold Borg Warner turbo, 5in SS MBRP
90 W350 CTD SRW big pump, big turbo, lots of fuel, 47RH billet suncoast triple disc and 20's
93 D250 CTD ext cab pump work, POD's
CUMMINSDODGEMAN3
Re: HID Conversion?
Postby 93DodgeCummins » Tue Oct 23, 2012 5:16 pm
any pictures?
93DodgeCummins
Re: HID Conversion?
Postby BILTIT » Tue Oct 23, 2012 6:49 pm
I forgot to get some, will try next time i have the truck out.
Derek B.
BILTIT
Re: HID Conversion?
Postby blackvmax07 » Sun Nov 25, 2012 7:29 pm
in for the pics as well
blackvmax07
