Bad crank sensor?
Bad crank sensor?
Postby 1stgensleeper » Wed Feb 06, 2013 10:44 pm
Hey guys, whatever help you could give me would be much appreciated. So the other day I noticed that my alternator wasn't charging my battery. Checked some wiring, changed a bad fuse, and still nothing. I replaced the alternator and it still wouldn't charge the battery. I did notice also my crank sensor was loose and had been rubbing the crank bad :oops: so could that be the problem? It's my daily driver so I need it fixed. Any help would be awesome. Thanks. :thumleft:
1stgensleeper
Re: Bad crank sensor?
Postby Mark Nixon » Thu Feb 07, 2013 9:28 am
Yes, that is most likely your problem, especially since you know it was rubbing.
The CPS does 2 things, it tells the ECM there is crank motion and that allows the alternator to charge.
It also runs the OEM tach, if you happen to be lucky enough to have one.
Postby 1stgensleeper » Thu Feb 07, 2013 3:43 pm
Thanks, I appreciate it. I'll put a new sensor on tonight and see if that does the trick.
1stgensleeper
Postby PToombs » Thu Feb 07, 2013 5:39 pm
There is supposed to be .050 clearance between the sensor and the balancer. It also turns on the AC and something else I can never remember.
Postby Bob L » Thu Feb 07, 2013 5:43 pm
PToombs wrote:There is supposed to be .050 clearance between the sensor and the balancer. It also turns on the AC and something else I can never remember.
Cruz Control :D
Bob L
NRA Life Member 1974
'92.5 D250 LE EXT.CAB...Getrag...All Original...No Rust...
Purchased new in late Oct.'92---128K Mi. Still Like New.
Bob L
Postby PToombs » Thu Feb 07, 2013 5:44 pm
Bob, I had that down and deleted it because I thought i was wrong! :roll: Thanks!
