Headlight switch replacement?
Postby Douglas » Mon Aug 03, 2015 3:15 pm
I think I need to replace my headlight switch in my 1990. Brake and turn signal work, but no running or headlights( the important bits IMO ).
How does that handle come out? I found the button at the bottom of the switch, but I can't get the handle out. Twist is some way? to one stop or the other? flat in some particular position? My finger tip gets a dent in it from pushing the release button and I still can't figure this out.
Any help most greatly appreciated.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Re: Headlight switch replacement?
Postby matthewh » Mon Aug 03, 2015 3:38 pm
No real easy way, I've always found I've had to kinda wiggle it back and forth rotationally (clockwise/counter clockwise) for it to release.
matthewh
Postby PToombs » Mon Aug 03, 2015 5:13 pm
Pull the lights on, push the button, then pull shaft out.
Postby Douglas » Tue Aug 04, 2015 12:50 pm
PToombs wrote:Pull the lights on, push the button, then pull shaft out.
Thanks Pete...I've done that, and been unable to get it out. I will try some more I s'pose...:)
cheers,
Douglas
Douglas
Postby Douglas » Wed Aug 26, 2015 5:33 am
OK, the push and wiggle did work. New switch in, and still no head lights/running lights or instrument lights.
Looked at the wiring diagram, and checked fuses in the box. All fuses healthy. turn signals work, so I am ruling out the main fusible link feeding that part of the tree. Am going to probe it with my DMM and see where I have voltage and where I don't.
Any likely suspects to examine?
cheers,
Douglas
Douglas
Postby Douglas » Wed Aug 26, 2015 2:16 pm
alright...is fixed. It was not the fusible link, it was the wire just downstream of it...green powder was all that was left of the Cu at the end. Diagnosed by checking everything on that circuit at the fuse box with DMM. Measure voltage, pull headlight switch to ON and voltage goes away. Was just like a fusible link failure I s'pose but when I cut out the bad part I brought the end of the link into contact( strrrretch) and the lights came on. No bad link.
cheers,
Douglas
Douglas
