88 Turn Signal Switch
Postby mrbro » Mon Oct 26, 2015 5:04 pm
Looks like I need to replace the switch. I have no turn signals, brake lights or tail lights, but the hazards work fine as well as the backup lights. Its an 88 w100 without a tilt wheel and all I can find are switches for tilt steering. Is it interchangeable? Do these switches fail in a repairable way or do they just fall apart over time? How hosed am I?
Thanks in advance.
mrbro
Re: 88 Turn Signal Switch
Postby mrbro » Mon Nov 02, 2015 5:38 am
Fortunately it did not need replacing, just a real good cleaning with some switch/contact cleaner was all that was needed. The headlight switch did have to be replaced due to rusty and corroded contacts.
mrbro
