Putting in freeon
Putting in freeon
Postby Bad93Cummins » Sun May 10, 2009 6:13 pm
My air blows but doesn't blow cold, what can I do about addnig freeon or what?
Thanks
Bad93Cummins
Postby Richie O » Sun May 10, 2009 6:20 pm
A shop can test and add R12. Its is getting pricey but last I knew it was still available. I converted a couple of trucks over to 134A. I just bought the wally world kit and drove it in. You are supposed to evacuate the system and all kinds of jazz but I just put it in. I had a quote of 1200 to fix one of my 89's a/c. I spent 35 bucks and just had to add some every year.
Postby Bad93Cummins » Sun May 10, 2009 7:31 pm
ya the guy at advance showed me a conversion kit for 39.99.
Bad93Cummins
Postby Richie O » Sun May 10, 2009 7:55 pm
O and if you put to much in,, you will be the first to know. I siezed one compressor up from overfilling it. Bled some off and all was well. :shock:
Postby burnt_servo » Mon May 11, 2009 2:52 am
i've been running r12a in my vw for the last 5 or 6 years .
it's a 1991 , so originally a r12 setup ( it has not been converted to 134a )
i plan to use r12a in my dodge once it's back togehther too .
my vw needed an adapter to fill the low pressure side .
you start the engine , engauge the ac , and watch the sight glass and fill the low pressure side till the bubbles just disapear ..... then don't add any more .
once a year i recharge the ac on my car , and it's good till i no longer need the ac , then it looses it charge over the winter months , unless i remember to run the ac a couple times a week .
'93 w250 .... stock ...
burnt_servo
Postby matchew » Fri Jul 03, 2009 5:41 am
FREEZE 12!!! It is better IMO and cheeper than R12. The freeze dissapates(sp?) heat better tha R12. Made mine blow about 8* cooler.
92 1 ton, 7" lift 37 military MT's on Hummer Alcoas, HE341, 4" downpipe to tailpipe, killer front bumper, 14mm H+R, +40 injectors, 03 dodge seats, loud tunes. 'Custom' Rustoleum paint.
matchew
