light flicker??
light flicker??
Postby dodgethis91cmns » Mon Aug 24, 2009 7:42 pm
i just noticed this about 5 minutes ago when i pulled in my driveway. i pulled in and turned just my parking lights on so my headlights werent shinning in my windows and the parking lights keep my pyro still lit and i wanted to let it cool down a bit before i killed it. i looked out the windsheild and noticed my lights were kind of flickering a little bit. what would be causing this?? i was thinking something along the lines of a voltage regulator, but im not electrically savy so figured id turn to the pros
1991 D350 non I/C pump tweaks, little bit of timing HX35, BHAF, 4in turbo back, valet switch, sirrius radio, boost pyro fuel PSI other stuff....
home build 518 WAITING TO GO IN
dodgethis91cmns
Postby Richie O » Tue Aug 25, 2009 5:40 pm
Could be the regulator. I have seen them do that before. Also a bad ground connection on the regulator will cause issues too. On my 89 it has a ground wire from the regulator directly to the negative post on the battery.
Postby dpuckett » Wed Aug 26, 2009 8:38 am
91 D350, nonIC. Brings back bad memories. One of the main reasons I sold my nonIC 91. In hindsight........ Anyway, that truck ate voltage regulators like a kid goes through candy on Halloween. I think I put 6 in one year. I finally relocated it, and it had the same reg in it for 6mo before I sold it.
DP
Postby 1dumrednek » Fri Sep 18, 2009 8:11 pm
i have this problem too. i replaced the alternator, regulator and ground the regulator diectly to the battery and it didn't fix it. my alternator guage twitches real bad too and my tach. also if i have the brights on, as soon as i signal or hit the brakes, i lose the speedometer. the speedometer twitches to the bass sometimes too. any ideas what's wrong?
A.J.
91.5 Power Ram w250 LE 5spd reg cab... totalled... again
2002 2500 laramie slt plus sport, nv5600, MBRP 4" straight pipe, edge juice w/ attitude, DC1 rims, kelly fierce attitude M/T
1dumrednek
Postby Ace » Fri Sep 18, 2009 10:26 pm
Something ain't grounded right somewhere. Or something is grounding that shouldn't be. Might try looking for cooked wires...
Ace
