Engine shutoff switch
Postby cumminz90 » Sun May 02, 2010 7:02 am
The other day the 93 didn't want to shut off with the key i havent had time yet to fool with it yet so im shuting it down manually. Question is what do i need to test to see if its working? And is there a fuse or relay that i can check to see if that mite be the problem? Thanks guys :D
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
Re: Engine shutoff switch
Postby meby » Sun May 02, 2010 8:57 am
cumminz90 wrote:The other day the 93 didn't want to shut off with the key i havent had time yet to fool with it yet so im shuting it down manually. Question is what do i need to test to see if its working? And is there a fuse or relay that i can check to see if that mite be the problem? Thanks guys :D
It will likely be a loose wire or the rubber tip broke off the shutoff plunger. If you don't know where to find the plunger, do a search here. It seems like i've seen pics or a diagram on here somewhere. Either way, it is located on the back of the IP.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby cumminz90 » Sun May 02, 2010 2:32 pm
ok thanks ill check it out and see wat i can come up with
cumminz90
Postby PToombs » Sun May 02, 2010 5:39 pm
If it won't shut off, you chipped the plunger tip. Power keeps it open, if you lose power, the truck will quit, not keep running.
Postby cumminz90 » Mon May 03, 2010 6:44 pm
Is it bad when you chip a plunger tip because what your describing is exactly what its doing and i have power with key on and none when i turn it off and it keeps running. How do i fix it?
cumminz90
Postby PToombs » Mon May 03, 2010 6:52 pm
It's not real bad. Some guys get all worried about where the pieces went, but I've chipped 3 or 4 and the truck still runs great. You need to remove the solenoid and replace it. You can't buy just a plunger. If you do a search, there's a link to a place on e-bay that sells VW solenoids for around $30. Dodge and Cummins want closer to $100 for one. Just cut or bend and break the top of the bracket on the end of the injection pump, it will give you tons more room for access.
Postby Richie O » Mon May 03, 2010 6:55 pm
PToombs wrote:It's not real bad. Some guys get all worried about where the pieces went, but I've chipped 3 or 4 and the truck still runs great.
Pete's latest truck movie.
http://www.youtube.com/watch?v=_OykV8Ez ... JcFCPmBAsw
. :lol:
Postby cumminz90 » Mon May 03, 2010 6:56 pm
thanks alot ill get searching for one of these rite now :D
cumminz90
Postby 921stgen » Mon May 03, 2010 7:50 pm
Heres the cheepest one you will find $10.00 + $4 shipping. I've had one for two years. Others say they are'nt very good though. http://volkswaparts.com/PumpSolenoid.htm
921stgen
Postby IowaCummins » Mon May 03, 2010 8:05 pm
here is a thread i made up a while ago.
viewtopic.php?f=4&t=7472
IowaCummins
Postby cumminz90 » Tue May 04, 2010 3:13 pm
Thanks for the thread im going to try the vw for ten bucks its worth a shot if it fails o well my labors free :D ill let you guys no how it works
cumminz90
Postby IowaCummins » Tue May 04, 2010 3:28 pm
yeah post your results in that thread so we can get an idea of how well they hold up in different trucks ya know
IowaCummins
Postby cumminz90 » Tue May 04, 2010 5:17 pm
will do
cumminz90
