aux power for gauges?
Re: aux power for gauges?
Postby 93DodgeCummins » Mon Sep 05, 2011 9:57 pm
yea i had the switch on. Now i lost my side lights and rear night time lights. only thing that works outside is the headlightsfor night time. But my turnsignals and brake lights work...im getting a new switch and i hope that fixes the problem. unless u guys have anybetter ideas
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Postby PToombs » Tue Sep 06, 2011 5:23 pm
Dash lights and tail lights are on the same fuse IIRC. Maybe you better go back and see if you shorted a wire to the gauges or just accidently popped a fuse.
Postby Richie O » Tue Sep 06, 2011 5:26 pm
The dash lights may be hooked to the same fuse pre light switch, but the dash has its own fuse after the dimmer.
Postby 93DodgeCummins » Fri Sep 09, 2011 8:55 pm
got it fixed it was the dimmer switch
93DodgeCummins
