OK Tach Question
Re: OK Tach Question
Postby Billy Boy » Mon May 03, 2010 7:50 pm
Personally, I used a dime! :lol:
1989 Dodge D350 Dually, Non I/C
Billy Boy
Postby Mudbug » Mon May 03, 2010 7:57 pm
A dime? are you serious? is that the right size? save me some time if it is
Mudbug
Postby Billy Boy » Mon May 03, 2010 8:05 pm
A dime is supposed to be .053" thick.
The specs for the kit from TST call for an air gap of 0.049" to 0.051".
I didn't have a feeler gauge at school when I did my KDP, so my dad (a heavy equipment mechanic) told me just to use a dime and it would be close enough. Apparently it was a reference he has always used in a pinch. Honestly, though, I have had my truck down for some paint since, so I have yet to verify that it in fact works. I think it should be close enough to do the trick, though...
Billy Boy
Postby gobigorgohome » Fri May 07, 2010 1:50 pm
ive heard of most of you guys usin isspro tach but i have been on their website and im havin no luck finding exactly what i want, what are the part numbers for the ones you all have? ive also heard about a plug and play harness for the 90+ models and i was wonderin about that too let me know htanks :grin:
91 4x4 with the 727, has the factory tach!
Boost gauge installed 27psi, new exhaust manifold here just not on yet. Pyro installed all glowshift units. 173 HP baseline before poor mans 4 inch dp
gobigorgohome
Postby 1STGENFARMBOY » Fri May 07, 2010 2:19 pm
Mudbug Billy Boy is right i just checked i got .051-.053 acording to where i checked.
Dar
Postby Tintacker » Fri May 07, 2010 7:29 pm
I used the dime trick when I replaced mine, works fine.
Don't have any brass feeler gauges (the manual specifies non-magnetic), hence the dime.
SOLD: :( '92 W250 LE auto PDR 190's, 3200 spring, Skyjacker 2" front springs with Bilstein 5100s
'01 2500 QC/SB 4X4 6sp, camper puller
Tintacker
Postby Mudbug » Sat May 08, 2010 9:11 am
Well this is an update, turns out it WAS the CPS. Got it today and put it on and the tach worked and my alternator started working again also. Now I just gotta fix my fuel shutoff solenoid and I will be back in business I guess.
Now I think I am getting paranoid, I havent ran the truck for a few days and it seems to idle just a tad rough.
But it may just be in my head lol. I dunno. I will drive it around a bit and see how things go.
Mudbug
Postby Fastback66 » Wed Jun 09, 2010 7:57 pm
On a side note, where do you suppose one could find another triple gauge pod like that. That's flippin sweet.
Vinny
78 D-200 Crew cab LWB converted to 4wd then converted to Diesel. 366 spring, custom pin, timing to head and pump tweaked.
75 W-100 SWB step side under construction. Soon to be 318 magnum/518 auto.
66 Charger 383/auto
71 Chrysler Newport hardtop 4dr. 360/727. Need drivers side body panels if ya got some.
Fastback66
