cbs
Postby james-93-12valve » Sun Sep 27, 2009 8:55 pm
PToombs wrote:It was a pita. I used the 2 existing holes and had to drill 2 holes on each side for the buckets to mount. The tough part was redoing the ramcharger mounts so they would sit nice. I started with a piece of 3/4 wood under the rear of the mount so it had a good feel for me, then ended up cutting 3/4 from the front to lower it down. A tilt wheel is a must, I'm kinda jammed under the wheel as it is. Smaller buckets would be better in a regular cab for sure.
Pretty sure I don't have any pics.
ok thanks
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
