engine wiring harness
Postby 1badve239 » Wed Mar 23, 2011 3:10 pm
i just replace my motor with one from a manual truck into my automatic truck and used the automatic engines head with manual block, the sensors on top of the head were broken when doing the swap, which sensors or wires do i really need to run and drive my truck? i know the two for the pump is a given along with the one for the tranny sensor on top of my pump, what else am i missin here?
1992 dodge w250 5spd le club cab
fuel screw, full travel throttle. 5in dp, hx40
1993 ext cab w250, built auto, PODS hx40 pump work, 3200, fuel pin, full travel throttle, electric lift pump
1badve239
Re: engine wiring harness
Postby gobigorgohome » Fri Apr 29, 2011 11:09 pm
for the cold months you will need the air temp sensor that controls the grids coolant temp and oil press. for knolegde purposes other then that it should drive just fine, i may have an issue with the neutral saftey switch for the auto but it should be able to be jumped
91 4x4 with the 727, has the factory tach!
Boost gauge installed 27psi, new exhaust manifold here just not on yet. Pyro installed all glowshift units. 173 HP baseline before poor mans 4 inch dp
gobigorgohome
