Turn Signals Blinking Fast
Postby collegekid » Wed Jun 08, 2011 8:56 pm
When I turn on my turn indicator, it blinks three times and clicks, then blinks three times really fast with no blink, WTH is this, its driving me nuts.
collegekid
Re: Turn Signals Blinking Fast
Postby ellis93 » Thu Jun 09, 2011 3:47 am
Could just be your flasher in the fuse box. That would also be the cheapest fix.
Postby Tacoclaw » Thu Jun 09, 2011 5:19 am
Are all of your bulbs working?
Most cars are set to blink fast when they lose a bulb, so you know it happened. The whole 3-blink thing is odd, but it's worth looking at as well.
Postby collegekid » Thu Jun 09, 2011 7:56 am
Ya, I went and got the flasher just have to install it, this morning on my way to school, the darn thing worked just fine, I think Im just gonna swap the falsher out and see what happens.
collegekid
Postby dpuckett » Sun Oct 16, 2011 8:55 pm
The fast blinking when you blow a bulb is after our trucks came out.
Wife's Dakota did this a couple years go, and my first thought was a flasher, but she said it was a bulb.
Postby RumbleFish » Mon Oct 17, 2011 8:23 am
Possibly a bad flasher, but I bet it's due to those fancy LEDs you just installed. Get a heavy duty electronic flasher, some even say they are led compatible. Old thermal flashers and no-load LEDs don't play well together.
Postby collegekid » Mon Oct 17, 2011 5:39 pm
they have been flashing fast since I bought the truck, which had the original lights all the way around, Im going to replace the flasher relay, already have one, just seems to be at the bottom of the To-do list, and see what happens, if I don't get what I want, ill try a heavy duty LED compatible flasher
collegekid
