No click with starter
Postby collegekid » Fri Jul 01, 2011 7:53 pm
Truck has been sitting while I did the KDP and new fuel system, replaced the IP, LP, installed regulator etc....Today I tried to start the truck, and lights came on, turn the key.....no click, no nothing, lights on the radio go out, but nothing on the starter clicks, I just took the starter out and when I hook it up to a charger, the solenoid hits, no spin, so bad starter, but even so, when I turn the key the starter should at least click, ideas?
The big red wire is hot in the column, big yellow wire is hot when you try to crank the truck (ignition wire) but touch em together and nothing, could I have forgotten to replace a ground on the front timing cover??
collegekid
Re: No click with starter
Postby ellis93 » Fri Jul 01, 2011 8:10 pm
All righty then :D. Battery chargers positive hooked to the battery cable lug and ground hooked to the starter case. You've taken some sort of jumper wire from the chargers positive to the small lug on the noid and no worky ,right. If I understand you right then there may be a stuck brush in the starter
Postby collegekid » Fri Jul 01, 2011 8:13 pm
Ya, but even with a stuck brush, when I turn the key, the solenoid should still hit, but Im getting nothing, the solenoid hits off the battery charger tho
collegekid
Postby ellis93 » Fri Jul 01, 2011 8:19 pm
Have you checked the clutch safty switch on your truck.
Postby collegekid » Fri Jul 01, 2011 8:21 pm
ya, when I bought it, it had an alligator clip in it and didnt need the clutch pressed in
collegekid
Postby ellis93 » Fri Jul 01, 2011 8:29 pm
Well siht! :bom:
The ground from the battery should hit the block on the driver side, maybe its loose?
If you have a test light, probe the small wire for the starter and get that riddle over with. If you don't have one ,buy one. Its a dang good investment on our trucks.
Postby collegekid » Fri Jul 01, 2011 8:40 pm
Ok, no power to the small wire, power at the smaller red one coming off the positive pole, but at the end of the lead, no juice...next step is.....im terrible with chasing down electrical gremlins
collegekid
Postby Tacoclaw » Sat Jul 02, 2011 8:07 am
There's a relay on your inner fender that goes to the starter relay.
viewtopic.php?f=30&t=10061
Here's a thread from a little farther down the page, same deal it sounds like.
Postby collegekid » Sat Jul 02, 2011 9:16 am
I just replaced the relay for the starter and shut-off, still nothing....
collegekid
Postby ellis93 » Sat Jul 02, 2011 9:19 am
Forgot about that thing :mad:
Check all the fuse links right there by the battery. Pull on them, if they stretch there bad.
Postby collegekid » Sat Jul 02, 2011 9:23 am
Taco THANKS!!! the alligator clip on the clutch switch had slipped off one of the terminals, fixed it, she turns right over. Thank all of you so much, got my truck back.....if ya'll are ever down this way, drinks on me
collegekid
Postby oldestof11 » Sat Jul 02, 2011 10:41 am
Where is "down this way"? :lol:
Hmm, 4x4, with a southern accent....
Texas?
Postby collegekid » Sat Jul 02, 2011 11:01 am
lol, ya dam right jon
collegekid
Postby oldestof11 » Sat Jul 02, 2011 11:40 am
Which part?
I have a good friend down at the tip, about 15mi from the US/Mejico border. I also have a great aunt and uncle (who I am named after) living in Dallas.
Postby Tacoclaw » Sat Jul 02, 2011 3:33 pm
Don't tell him, he just wants free beer!!!
