Hazards Dead
Hazards Dead
Postby Diesel » Mon Aug 29, 2011 12:58 pm
Ever since owning my truck the hazards have been inoperable. I'd like them to work. Where should I start. By the way the turn signals themselves operate.
1991.5 D250 Intercooled A518
Diesel
Re: Hazards Dead
Postby SNOOT » Mon Aug 29, 2011 1:46 pm
Cycle the switch several time vigorously and see if that corrects the problem. Some times the switch gets lint in there and working it a few times clears it up.
1993 W350
SNOOT
Re: Hazards Dead
Postby manyholes » Tue Aug 30, 2011 10:57 pm
mine still dont work unless i have a signal turned on, give it a go
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Re: Hazards Dead
Postby dazedandconfused » Fri Sep 02, 2011 2:52 pm
Mine just died as well on the duck. If I figure it out I'll let you know.
Re: Hazards Dead
Postby Tacoclaw » Fri Sep 02, 2011 3:41 pm
From what I recall, the Hazards get their power directly from a specific fusible link under the hood. There should be a plastic connector right after one of the links, and that's the one that goes to the hazards.
I'm not too sure of the routing after that point, so if it isn't that I won't be much help. :oops:
Re: Hazards Dead
Postby dazedandconfused » Fri Sep 02, 2011 4:24 pm
Tacoclaw wrote:From what I recall, the Hazards get their power directly from a specific fusible link under the hood. There should be a plastic connector right after one of the links, and that's the one that goes to the hazards.
Ding, ding I went out and was messing with mine and noticed my replacement fuseable link was blown. It also controls the fan contol on the heater. I replaced my fuse and they worked along with my heater. It's the second wire from the left and believe it was a orange wire. Here is a pic of it. It's the wire that is now missing from the junction.
Re: Hazards Dead
Postby Mark Nixon » Sun Sep 04, 2011 8:56 pm
Just little note that I'll share.
If you try to use a '91 engine harness with a '92 or '93 Dash harness, the Hazards are the ONLY thing that will not work between the 2.
This goes for Intercooled or Non-intercooled on the '91 engine harness.
I found this out when I put the Carhauler back together a while back. :roll:
It was verified again, when a buddy put his crew cab together using a '93 engine harness with a '91 dash harness.
Re: Hazards Dead
Postby bmoeller » Sun Sep 11, 2011 5:49 pm
The multi-function switch can play a role in the problem as well. Replaced mine, and the turn signals and 4 ways work properly again. :D Was only something like $60 or so.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: Hazards Dead
Postby Diesel » Mon Sep 12, 2011 2:12 pm
My turn signals works just fine. I tried hitting the hazards rapidly but still nothing. Could it be that there is a fuse burnt? What does it share a fuse with?
Diesel
Re: Hazards Dead
Postby dazedandconfused » Mon Sep 12, 2011 2:34 pm
Look at my post above. The fusible link under the hood was bad giving me my issues.
Re: Hazards Dead
Postby Diesel » Mon Sep 12, 2011 5:27 pm
Thanks but how do I know if a fusible link is bad?
Diesel
Re: Hazards Dead
Postby dazedandconfused » Mon Sep 12, 2011 5:34 pm
They say you can pull on them or you can take a multimeter and puncture the wire to check for 12v's.
Re: Hazards Dead
Postby PToombs » Mon Sep 12, 2011 5:39 pm
Did you check the flasher unit? The signals and hazards each have their own. For a quick test just swap them.
Re: Hazards Dead
Postby Diesel » Mon Sep 12, 2011 7:07 pm
Oh I didn't know that. Is the flasher unit next to the fuses?
Diesel
Re: Hazards Dead
Postby PToombs » Tue Sep 13, 2011 5:41 pm
Yup! Both of them. The fuse box is marked signals or hazard. The hazard is the one out on the point. The horn relay is next to it and the flasher is on the fuse end.
