lights flickering !!! help i have done everything i know
Postby swampthang » Wed Aug 29, 2007 6:26 pm
ok guys my truck is a 1991 and all the lights are flickering not going on and off just flickering
i have replaced the volt reg put new bat cables on cleaned the ground had the alt tested added two grounds one from the bat to the core support and one from the engine block to the frame still the lights flicker ?? what is there left to do
JC
Bloody Knuckle LLC
Transport,custom fabrication and used parts.
Based out of Halltown Mo 65664
JC
bloodyknucklellc@gmail.com
swampthang
Postby Philip » Fri Aug 31, 2007 7:39 am
Is it doing it sitting still or driving it?
Have you checked the plug on the headlight switch? It is has a noted problem of burning out terminals.
Postby swampthang » Fri Aug 31, 2007 3:54 pm
it will do it sitting stillor driving after putting on all the extra the grounds it is not as bad but it still has a noticable flicker when driving and sitting still at idle it seems to go away when i load the engine like you would to bring up boost ?? the head light plug is fine and the switch also looks fine and i just replaced it a month ago
JC
Bloody Knuckle LLC
JC
swampthang
Postby wannadiesel » Fri Aug 31, 2007 6:52 pm
Try a genuine MOPAR regulator - you can probably pick up 4 for $20 at your local automotive recycling facility.
Best dyno: 408/844
wannadiesel
diesel guru
Postby swampthang » Fri Aug 31, 2007 7:54 pm
i actully tried that i pulled the reg off of the 82 crew cab it looks the same voltage is the same on the guage in the dash the reg from the 82 has the mopar logo on it
JC
Bloody Knuckle LLC
JC
swampthang
Postby BEARKILLER » Sun Sep 02, 2007 9:30 am
Go to a Dodge parts-counter and get the BLUE MOPAR regulator, about forty bucks, and if it still flickers, it ain't the regulator.
These are considered a performance item, and thus, have no warranty, but no warranty is needed.
#4 = 1991 D-350 LE Getrag
BEARKILLER
Postby Diesel Nut » Thu Apr 17, 2008 9:19 am
Ok, mine do this too on the 91.5. Only does it with truck running, will not with engine off. And where is the regulator located?
I have a goofy looking silver tube a little bigger than a AA battery that hangs down under the dash and plugs into a modular plug with 3 prongs. WTF is that? My 90 doesn't have that anywhere I have found yet.
2006 Dodge 2500 4x4
1991.5 250 Reg cab - Parts Runner
1990 350 Reg cab - Wants to be fast
www.dieselnut.com
Amsoil Dealer
Diesel Nut
