Charging Issues... Again
Postby peobryant » Thu Sep 15, 2011 9:06 am
I'm having more issues with my truck charging. My voltmeter only shows about 10 volts (on the dash) and seeing as I just replaced the alternator not more than 3 months ago, and the voltage regulator yesterday, I'm thinking the battery is at fault because it's older than any of the other parts. My question though, is would a bad battery (one that won't hold a charge) make the voltage meter only show 10 volts, or would it still show the normal voltage but not take a charge? I know some may say the dash gauge may be off but my windows roll down much slower and my lights aren't nearly as bright so I know she isn't getting the voltage she needs.
If the battery can't be the culprit, what do you suggest I check? I suppose the ZAPA Alternator could be bad but I wouldn't assume so in such a short period of time.
Thanks for any help.
Re: Charging Issues... Again
Postby ellis93 » Thu Sep 15, 2011 9:26 am
If you bought a reman alt,its very likely that it could be bad. Does the volt gauge go up if you rev your motor?
Postby BobS » Thu Sep 15, 2011 10:08 am
Maybe first try putting a real voltmeter on the alternator to get the reading. I never totally rely on the one in the dash and consider it as a relative indicator at it's best. Over the years I have seen them from spot on to being off by +/- 5 volts.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby firstgenjunkie » Thu Sep 15, 2011 11:31 am
Have you load tested your battery to see if it's the problem? Vato Zone or any of the others should do that for free.
1992 Dodge D350 Dually. EV2 Pyro & Boost, BHAF, Denny T Stage 2 pin, 366 spring, 4 inch exhaust and mildly tweaked pump. 2nd gen split bench, full replacement bumper/grill, and mobile comm suite.
firstgenjunkie
Postby peobryant » Thu Sep 15, 2011 1:04 pm
ellis93 wrote:If you bought a reman alt,its very likely that it could be bad. Does the volt gauge go up if you rev your motor?
That's what I'm worried about. It's not like replacing the alternator is hard, but I have so little free time now I'd rather spend it with my son than working on my truck. Nope, volt gauge stays low, and when I put it in gear it drops a little lower.
BobS wrote:Maybe first try putting a real voltmeter on the alternator to get the reading. I never totally rely on the one in the dash and consider it as a relative indicator at it's best. Over the years I have seen them from spot on to being off by +/- 5 volts.
Unfortunately I don't have access to one right now. I tried getting ahold of my father earlier to see if he has one, but I haven't heard back as of yet. I know the dash gauge isn't the most accurate, but like I said the windows and lights combined with the dash gauge are more than enough for me to know she isn't charging.
firstgenjunkie wrote:Have you load tested your battery to see if it's the problem? Vato Zone or any of the others should do that for free.
On my way to do that after I pick up Dallas from work. This would be so much easier if she had a car... :?
Thanks for the help.
Postby dazedandconfused » Mon Sep 19, 2011 3:17 pm
Did you get it figured out?
