If the switch is shorted, that would just mean it could start whenever.
If the wire that goes from the switch to...whatever it switches...is rubbed through, it would still short 12v to ground when the switch is closed. Put the truck in drive and see if it still pops fuses when you turn the key on.
You may still be on the hunt.
