93 wiring diagrams ( ALL OF'EM)
Re: 93 wiring diagrams ( ALL OF'EM)
Postby Farmboy92_2009 » Thu Nov 27, 2014 2:04 pm
Does anyone have a picture they can post up of the wires that are connected to the VSS??? The guy that has my old 92 is trying to fix the speedometer and when I originally bought the guy literally cut all the wires leading back to the drive train. So were trying to see which color coded wires needs to be spliced into a pigtail and connected to the VSS. Thanks in advance.
92 - SOLD. new ride.... 96 CC LB Dually 4x4 auto - Goerend's TD Convertor & HD VB, Autometer EGT/Boost/Trans Temp, 5'' TBE 6'' tip, #100 plate, II Dragonflow 5x.016's, CAI. Sitting in the shed - DDP 042 DV's, 80'' long Trac Bars, and nice purdy Full Replacement Ranchand :) WTB - 4k GSK, 60 lb VS's, and a 64mm turbo.
Farmboy92_2009
Postby dwfine » Thu Jan 14, 2016 10:14 pm
Can you email me the pdf for the wiring diagrams?
When I print them they run together and make them unusable.
dwfine
dwfine
Postby ellis93 » Fri Jan 15, 2016 11:57 am
There is no pdf,these are scans made and loaded onto photobucket,then posted here.
What diagram are you needing specifically? I'm not on here much anymore but can check back soon.
Postby dwfine » Fri Jan 15, 2016 12:21 pm
Brake wiring diagram from computer though anti locks to brake lights and warning lights.
I have a problem to find.
dwfine
Postby ellis93 » Fri Jan 15, 2016 5:33 pm
Figures I'd check this after leaving work :roll: I can get them tho.
Btw why not just unplug the abs box (behind the glovebox) and live a happy life? Once it's unplugged the lights take care of themselves,turning off. Of course.....if the lights being the issue.
Postby txs » Tue Jan 02, 2018 8:55 am
pics went tits up, would anyone care to repost them?
txs
Postby thrashingcows » Thu Jan 04, 2018 5:44 pm
If the original poster goes into the "edit" point of the post and then adds "~original" to the pic URL just before the [/img] the pics will work again. Then to save them for good you can go to https://web.archive.org/ ...I did this to most of the "how to" threads I posted up over on the DTR.
thrashingcows
Postby ellis93 » Thu Jan 04, 2018 7:11 pm
thrashingcows wrote:If the original poster goes into the "edit" point of the post and then adds "`original" to the pic URL just before the [/img] the pics will work again. Then to save them for good you can go to https://web.archive.org/ ...I did this to most of the "how to" threads I posted up over on the DTR.
Tried typing that before the first img and the last on the link,neither place worked. That's all above my pay grade,typing coherent words,sentences and paragraphs is about as technical as I'm going to get.
Postby thrashingcows » Thu Jan 04, 2018 7:42 pm
Sorry it is supposed to be..... ~original
thrashingcows
Postby thrashingcows » Thu Jan 04, 2018 7:50 pm
fixed first post.....;)
thrashingcows
Postby thrashingcows » Thu Jan 04, 2018 7:55 pm
Turns out just copy the image location, then post in the img quotes, and then add the ~original gets it working....;)
thrashingcows
Postby thrashingcows » Thu Jan 04, 2018 8:01 pm
And here is the link to them archived....should always be available here if the pis in this thread ever stop working. ;)
https://web.archive.org/web/20180105030 ... 7&start=15
thrashingcows
Postby Retika » Thu Feb 28, 2019 2:18 am
Much obliged Ellis, I approached that stuff from the school I went to until they changed the secret key on me lol I have a lot of wiring charts for 98 Cummins and brave, and avoid procession, yet I didn't get the wiring graphs for my truck before they changed the secret key.
Retika
