TRENDZ wrote:Here's what Ive found. My truck was doing the volt gauge "wiggle wiggle" thing. All the lights would flicker, etc...I finally went out and did some real diagnosis to figure out why, since my previous truck did the same thing. After several tests of wiring, and consulting the factory service manual, I found a voltage drop of 0.8 volts to the blue wiring to the regulator. Tracing the wiring in the manual, I decided to check the fuses that are common with this circuit. Fuse 11, 12, and 13 all had the same drop, their source is one of the "key on" circuits in the ignition switch. I suspect the switch is the culprit, but I haven't checked that far yet. I have however used a jumper wire from the battery to the regulator, to try the charging system. It functions perfectly with the jumper wire attached, and pulses with it removed.
There is still the possibility that the source that FEEDS the ignition switch is weak. The feed originates from the heavy cable from the alternator/battery connection, thru a fuse link, thru the bulkhead connector, than to the ignition switch.
I will post my final findings when I confirm the repair. Hope this info helps.
TRENDZ wrote:can't tell you what's wrong, but I can tell you how to fix it.
What happens is, somewhere in the wiring to the voltage regulator there is resistance. This causes the regulator to "see" lower voltage than the rest of the system, causing the regulator to turn the field windings "on" when it really doesn't need to. The extra voltage overcomes the resistance and suddenly the regulator "sees" way to high of a voltage reading. This causes the pulsing you're seeing.
The way I overcame this, was to add a wire from the battery, to a relay, feeding the blue sense wire on the regulator. After doing this, the voltage gauge is rock-steady and I get a dvm reading of steady 14.4 volts.
I did have a problem when I did this at first. I used a hella relay without an internal suppression diode. Relays that don't have a suppression diode release a 300 to 500 volt short duration spike from the coil at very low amperage when turned off. This fried my regulator after the third time I shut the truck off. I put a relay in it with a suppression diode and it has been fine ever since.
Now, the best way would be to find the actual source of the voltage drop, but this is very simple way of overcoming the problem.
