Wipers just stopped :/ Wiper module?
Postby Diesel » Wed Dec 21, 2011 3:14 pm
So my wipers 100% stopped working. Checked fuse and it's good. Is it the module? Is that the box screwed by 1 screw sorta behind the ash tray and has a large flat wire connector going to it? Repairable or where do I buy a new one?
1991.5 D250 Intercooled A518
Diesel
Re: Wipers just stopped :/ Wiper module?
Postby delsilver » Wed Dec 21, 2011 4:10 pm
If you are sure it is the motor this will have no bearing on your problem.
There are plastic clips on the linkage under the cowl which become brittle and break. Haven't experienced this myself but it is appaently a comon problem.
Delsilver
93 W250
Fuel pin turned 90 deg, starwheel turned down, timing 1/8 adjust
delsilver
Postby Diesel » Wed Dec 21, 2011 6:29 pm
It's not the motor. I think it might be the module. I'm going to try and fix the module unless someone knows where I can buy a new one.
Diesel
Postby Tacoclaw » Wed Dec 21, 2011 6:34 pm
So you're sure it's not those little plastic clips he's talking about?
Postby Diesel » Wed Dec 21, 2011 6:38 pm
Only reason I don't think it's the clips is because I don't hear the motor coming on. I'll check again tomorrow and have a closer listen.
Diesel
Postby cmann250 » Wed Dec 21, 2011 6:39 pm
I looked at for a module around me and the parts stores didn't have them. I stay away from the dealer like the plague, but i keep my eyes peeled at the junk yards. I just decided i can live with goofy wipers :?
Postby Diesel » Wed Dec 21, 2011 9:15 pm
Looks like quite a few 90's molars use this part. I'm going to probably just scour a junkyard to see what I find. Still kinda weird that The wipers won't move at all. Seems like others with relay issues just lost intermittent functions.
Diesel
Postby Diesel » Thu Dec 29, 2011 9:43 am
Ok now I am thinking I do hear the motor coming on. What is the part number on the plastic clips if you will?
Is it Dorman 118301? "Wiper linkage bushing"
Diesel
Postby ellis93 » Thu Dec 29, 2011 11:12 am
You can walk into nearly any part store that has a HELP! section and they'll have them.
Postby Diesel » Fri Dec 30, 2011 3:09 pm
Got the bushings...how many screws underneath the windshield rubber seal? I found one on the passenger side and I think drivers side. Is there one in the middle?
Diesel
Postby ellis93 » Fri Dec 30, 2011 3:28 pm
That's all that's by the windshield. The rest are in the engine bay side.
Those bushings need to be installed either dry or with a silicone/graphite spray. Grease or oil will make them rot fast
Postby Diesel » Fri Dec 30, 2011 3:37 pm
Thats weird. I got the two by windshield and all engine bay screws but it wont pull away from the center.
Diesel
Postby ellis93 » Fri Dec 30, 2011 3:46 pm
Dirt and garbage held mine in place hard. I really don't remember any other screws in there.
