Need some help guys
Need some help guys
Postby mhuppertz » Mon Jan 30, 2012 6:20 pm
Today leaving a client site my power cut in the truck and a bunch of smoke came out of the top of the dash and defroster vent. I still had interior lights and brake lights, but not much else. I found some crispy wires, and also found that the middle bus bar on the back of the fuse panel was live, but the outboard br was not. I jumped a wire over and then could start the truck and everything worked, as long as that wire was there. When I kill the truck I have to pull that wire because the electric fan and some other things keep running otherwise.
I am assuming a fried a fusable link, but am having a hard time tracking down link locations. I have the FSM, but it's still a daunting task.
Any advice?
Thanks,
Mark
mhuppertz
Re: Need some help guys
Postby PToombs » Tue Jan 31, 2012 5:51 pm
Since the smoke came out of the dash, I lean more towards a problem in the cab. Maybe the ignition switch burned up? It may have fried a fusable link also.
Postby Tacoclaw » Tue Jan 31, 2012 6:22 pm
All your key-on stuff underhood is connected through the same wire. My AC clutch hot fried one night and wiped most of my in-cab stuff, then my reverse light hot shorted and took out almost 3/4 of my harness. It'll still get to the light blue wire that comes off your key switch if something underhood shorts out.
Postby mhuppertz » Tue Jan 31, 2012 6:32 pm
The switch is still working for some stuff liek the power windows. Hoping it's just that fusable link.
mhuppertz
