New multi-function killed turn signals?
Postby ss_storm » Thu Feb 02, 2012 3:54 pm
Just installed a new headlight switch and a new multi-function which resolved all my head light issues but now my turn signals have stopped working- Have you guy's heard of this happening or did I get a defective unit?
Thanks
Blake
ss_storm
Re: New multi-function killed turn signals?
Postby PToombs » Thu Feb 02, 2012 5:11 pm
Why did you change it? I would say something else is the problem if you replaced it and it's still broke.
Postby ss_storm » Thu Feb 02, 2012 5:31 pm
I was replacing everything having to do with the head lights- Also my windshield wipers were not functioning quite right
BUT the blinkers worked just fine.
Are they on a separate fuse?
ss_storm
Postby oldestof11 » Thu Feb 02, 2012 6:54 pm
Clock spring?
Postby ellis93 » Thu Feb 02, 2012 9:03 pm
oldestof11 wrote:Clock spring?
That's for the horn and cruise only
I'd say that you'd have gotten a bad part if they worked proper before.
Postby ss_storm » Thu Feb 02, 2012 9:37 pm
Re-installed old Multi-function and the turn signals still aren't working-
What fuse would handle the power for them?
Which relay is the flasher relay?
ss_storm
Postby ellis93 » Fri Feb 03, 2012 5:25 am
