by xohcef » Mon Apr 16, 2012 7:12 pm
So truck runs fine and everything sounds/operates as it should while it's running. Once I idle down, turn the key off and remove it from the ignition is when it starts givin me fits. The truck will sit as it should for a second or two but then the (main relay?) or some kind of major switch starts acting funny. It turns on for a few seconds and will run the electric fuel pump, parking brake light, wait to start light, water in fuel light, voltage gauge and oil light, then shuts right off for a few more seconds. On for a few more then off. I do not know what is going on with this thing. I keep reading about voltage regulators going bad on these trucks but I'm thinking more along the lines of an ignition switch? Just because it's doing this while the key is off and out of the ignition. Anyboyd had any experience or know what might be happenin in my CTD? Thanks in advance guys.
93 d350 extended cab dually, NV5600, he351cw, DDP stage 3, industrial man ported, ported head, 60# springs, 354 spring, holley blue, aeromotive fpr, South bend single disc/hydros, kelderman dual bag.
