Well, then it's time to do some accessory removal.
Unhook ANYTHING that is not stock to the truck, radio, amps, CBs, brake controller, etc.
Do it one item at a time until either nothing is left, or until the problem goes away.
It's quite possible you have some cheap POS that went bad and it's back feeding power where it's not supposed to be.
Another thing that HAS done something like you describe, and I've mentioned it before, is the fusible links.
I had one fry on my old flatbed once and when I hit the power window switch, the info center lights would come on!
Not long after I fixed that snafu, I replaced the whole under hood harness and no more of that crap!
