DodgeFreak wrote:thanks the images didn't show up....
DodgeFreak wrote:quick question, if they wired the fld wires with a different color is there anyway to tell if its fld wires and not something else??? say i pull the plug from the volt reg, top plug should be 12v hot with key on??? and then bottom should be fld wire to alt and another fld wire to the top...
