Another overharging problem...
Postby poof » Wed Jun 27, 2012 7:46 pm
I have an 89 dodge w250. im having an overcharging problem. i have burnt up 2 battery's and 5 regulators already this year. I read a post on here about putting a relay on your regulator in order to get consistent power to the regulator. but i have not seen any change in the charging. My truck before it is running has a good 14 volts at the battery. relay has 12 coming from the green ignition wire. and 11 volts from the relay. After starting is where it gets all weird. i have 17 volts at the battery. 16v out of relay. idk what to do! is there somewhere else i should look. all he connections are good. grounds have been cleaned and checked. does anyone also know where the green wire goes from the regulator?
poof
Re: Another overharging problem...
Postby Remps » Thu Jul 05, 2012 7:17 pm
Screws are still holding the regulator tight? Did you scrape paint to get a good ground? You could try running a wire from the negative batt post to the back of the regulator to make sure its really grounded.
