how do i test my vss and my tps?
Postby 78fordf150ranger » Tue Aug 28, 2012 6:16 pm
My Speedo has never work for as long as I have owned along with the over drive.I found a bunch of burnt wires going to the over drive solinode and vss, I fix the wires and inspected the vss gear for signs of wear and nothing seemed out of place.
What else could it be and how do I test the system?
78fordf150ranger
Re: how do i test my vss and my tps?
Postby directinjktn1stgen » Sun Sep 23, 2012 9:18 am
u really need a wiring diagram of it and check reistance with an ohm meter and voltage where it should be and for good grounds is where id start you should find your problem
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
