voltage regulator?
voltage regulator?
Postby (92)cummins » Mon Oct 01, 2012 4:43 pm
where is the voltage regulator on a 92 located, my truck wont charge and was gonna try replacing my regulator
92 w350 srw flatbed
1985 D350 crew cab diesel conversion in progress
79 w200 power wagon
93 D350 drw 5spd getrag 4 door donor
90 D350 auto(fried) flatbed
93 D250 auto
(92)cummins
Re: voltage regulator?
Postby PToombs » Mon Oct 01, 2012 4:45 pm
It's in the PCM, it does all that stuff. Located behind the battery in the fender. Why do you think it isn't charging?
Postby (92)cummins » Mon Oct 01, 2012 4:51 pm
well im not the best with electronic stuff but i thought i read somewhere the regulators were a prblm and with all my part laying around id just throw parts at it till it works
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Postby PToombs » Mon Oct 01, 2012 4:56 pm
Put a voltmeter on it and see what it charges. Should be 14.6 or so. If you turn on the lights and heater and it drops way down, it's probably the alternator. If it's only 12 ish, you need to figure out if it's the alternator, PCM, or the crank sensor is bad and not telling the PCM the engine is running.
Postby (92)cummins » Mon Oct 01, 2012 5:01 pm
its constantly12.89 and i have a bad crank sensor so i took it off, didn't know i needed it to tell engine to chargeand just run the tack, i feel stupid lol
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Postby PToombs » Mon Oct 01, 2012 5:03 pm
Don't feel stupid, you just didn't know. ;) Lots of both around here! :lol: The sensor also turns on the AC, cruise control, and something else I always forget...... :roll:
Postby (92)cummins » Mon Oct 01, 2012 5:07 pm
this is a real friendly place lol but i looked on my 93 and 90 and they dont have cranj sensors, y?
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Postby PToombs » Mon Oct 01, 2012 5:16 pm
The 93 should have one unless it was removed and a regulator added. The other stuff can be rewired to not need the PCM. Maybe the PCM went bad on it and was bypassed, hard to say.
The 90 won't have one. It will have a regulator on the firewall, just near the head. When they went to Intercooled in 91.5 they added most of that extra crap.
Postby (92)cummins » Mon Oct 01, 2012 5:27 pm
alright ill try throwing a new crank sensor on it and just use a boost pack whenenr i wanna start it
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Postby (92)cummins » Wed Oct 10, 2012 9:16 am
i put a new crank sensor on and it fixed my problems kinda spendy for a lil magnet
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Postby PToombs » Wed Oct 10, 2012 4:39 pm
Cool you got it fixed! 8) How much was the little bugger? From the dealer?
Postby (92)cummins » Wed Oct 10, 2012 7:07 pm
bout $90 from auto value,ha the gold colored brackt better be gold plated
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Postby (92)cummins » Thu Oct 11, 2012 4:24 pm
now i gotta wait for the next thing to break
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Postby PToombs » Thu Oct 11, 2012 5:10 pm
Shhhhhhhhh!
Postby (92)cummins » Thu Oct 11, 2012 5:17 pm
ha i probably shouldn't have said that
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
