Hansen01 wrote::( Now your getting all fancy with shrink wrap and sthi. Your gonna make my truck jelous cause i keep putting that off
ellis93 wrote:You won't have any problems out of the mod,mine has been done for years and used often. Most of my wheelin and dealing is done at night after I close down the shop.
If those fancy projector headlight thinger ma jigs is out of the budget,look into the silverstar headlights. I've a set and they light up the road well
PToombs wrote:When I did mine I used the existing wiring most of the way. I cut it at the bulkhead and spliced in the wires from the relays there. I used the plugs at the lights, but removed the terminal for the ground and soldered the 12 ga wire right to the old terminal.
tampabayBill wrote:NO !! DO NOT USE PLUMBING SOLDER !! Drop by the hardware store or radio shack and get some rosen core solder used in electrical/ electronic work.
RumbleFish wrote:Oreillys has that solder as well.
cmann250 wrote:Menard's did too and they're on the edge of town, not the middle.
