flasher power
flasher power
Postby skilletky » Wed Dec 26, 2012 2:09 pm
my flasher aint working. i got not power to the hazzard fuse. anyone know where the power supply wire to the hazzard fuse (pink wire with white tracer) gets it power from? i cant see the wire diagrams too well. i cant seem to find it. it looks like it goes to the fire wall harness. if i am right, then i got no power at the fire wall connector. does it get power from the pcm?
skilletky
Re: flasher power
Postby CumminsPower59 » Wed Dec 26, 2012 2:16 pm
The wire feeding the hazard fuze comes through the firewall connector at location #23.
It comes from its own fusible link, fed from a two prong connector that comes off the positive terminal on the battery, which the other wire goes to the starter...
Hope this helps ya, if not I can text you a clear, zoomed in picture of the diagram...
Re: flasher power
Postby skilletky » Wed Dec 26, 2012 2:19 pm
i thank you sir. that helps out a whole lot!!!!
skilletky
Re: flasher power
Postby CumminsPower59 » Wed Dec 26, 2012 2:20 pm
You're welcome ;)
