Speedometer surges
Speedometer surges
Postby Chuck Snider » Thu Oct 25, 2007 1:32 pm
Man,
I've been trying to fix my speedo surge to no avail.. I've put in a known good distance sensor ,change my computer ,changed the speedo still surges.It works fine for a while then goes back to surging.. anyone else fixed a surging speedo?.. Maybe I'll pull the dash and reground the panel ground and see what I come up with?.. thanks for any advice..
93W250 CC auto
92W250 CC NV4500
Chuck Snider
Postby gomerpile » Thu Oct 25, 2007 2:51 pm
well ive heard people grounding the sensor them selves and even take it as far as running all new wires up in to the dash :shock: :D
1992 Dodge D-250 LE auto, LSD w/3.54, about 200,000+ miles.Isspro Pyrometer , Sunpro tach,Tractor Supply Boost Gauge, Old Smokey Fuel Pin,4 turns on fun srew, starwheel turn CCW 1 turn, 40hp injectors, BHAF,16 cm housing.Sony Head Unit.
gomerpile
Postby KTA » Thu Oct 25, 2007 3:34 pm
I find alot of problems with the gear reducer adapter between the trans/t-case and the speedo sensor.
Postby Chuck Snider » Fri Oct 26, 2007 7:45 am
I'll try "borrowing" the gear reducer from my 93 and see what happens. Thanks for the replys.....
93W250 CC auto
92W250 CC NV4500
Chuck Snider
Postby Chuck Snider » Fri Oct 26, 2007 10:13 am
KTA wrote:I find alot of problems with the gear reducer adapter between the trans/t-case and the speedo sensor.
Bingo!!!!!,
that was my problem right there... Is there a rebuild kit for that adapter?
93W250 CC auto
92W250 CC NV4500
Chuck Snider
Postby KTA » Fri Oct 26, 2007 1:43 pm
They are junk when they are wore out, buy a new one.
Postby Chuck Snider » Sun Oct 28, 2007 1:49 pm
I'm on it,
I found a place that has them and they will match the ratio to what I need. I just hook up the distance sensor without the ratio adjuster and record true mph to what my speedo is reading and they'll dial me in. I'm using a GPS for true mph....
here's the place that has them if anyone might need one on the future..
http://www.transmissioncenter.net/727Transmission.htm
93W250 CC auto
92W250 CC NV4500
Chuck Snider
Postby 2001shrtbedcummins » Sun Nov 25, 2007 7:16 pm
what about a 2wd with surge?
91 D250 smoke screw turned a little... trying to figure out how to get my big @$$ hands in there and crank up the fuel screw a hair.
2001shrtbedcummins
Return to Electrical
