List of sensors.
List of sensors.
Postby ByronRACE » Fri Nov 01, 2013 10:43 am
Hi Guys,
I have a cummins 5.9 out of a '92 Dodge and I'm retrofitting it into a '75 Grumman Step Van that has been converted to an RV.
Most of the sensors on the engine are not needed (I think), and as I remove them I'd like to document them and label what they are and where they were located. I've searched for an electrical diagram for the engine and have not found it. Is there an online source. No, I have not spent the money for a proper service manual since I've found nearly everything needed online.
Does anyone have a list of sensors? Should I make one, and photograph them all as I remove them? This might be a useful sticky.
The only engine sensors I plan on running are the engine temp, oil pressure and water-in-fuel switch wired to a dummy light and an egt. Water temp and Oil Pressure will be replaced with the original Grumman/International sensors so the dash works right. I may leave the crank sensor there so I can run a tach at some point. Is there anything else I need?
There are a couple sensors on top of the intake that I don't know the names of, a small one and a big one on the side of the block on the driver's side; perhaps oil pressure and water temp, a TPS sensor that I don't need I think (46rh), and maybe 1 or two more sensors I'm not remembering.
Thanks in advance,
Byron
ByronRACE
Re: List of sensors.
Postby BC847 » Fri Nov 01, 2013 11:02 am
Hey Byron, WELCOME to our forum. :)
Perhaps this will help a little . . .
Your '92 will include a second air temperature sensor on the intake-log's cover-plate that is associated with the KSB (or cold-start) circuit (mounted of the side of the injection pump.
Postby ByronRACE » Fri Nov 01, 2013 1:08 pm
Wow, thanks a ton! That helps a lot.
ByronRACE
Postby ofelas » Mon May 04, 2015 5:16 pm
BC847 - on my 91.5 intercooled where can I find the thermoswitch # 3408645/4327029 that controls OD function on the A518 ?
Is it below the head behind the fuel filter or is it in a tranny line somewhere ?
R12 = liquid bilit
ofelas
Postby BC847 » Mon May 04, 2015 5:32 pm
Postby ofelas » Wed May 06, 2015 8:47 pm
Thanks.
The one on the trans is two orange wires correct ? Got part # ?
Also need the part number of the 3 wire cold operation "thermoswitch" on the side of the cylinder head.
R12 = liquid bilit
ofelas
