aftermarket gauge cluster
Postby directinjktn1stgen » Tue Nov 05, 2013 4:59 pm
Ive been tossing the idea around for all isspro gauges ( replacing all factory gauges ) Wondering if anybody has done this before. Wondering if using all factory engine sensors is possible? Just an idea right now may turn into more work than im wanting to do.
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
Re: aftermarket gauge cluster
Postby PToombs » Tue Nov 05, 2013 5:16 pm
Most likely not. The Isspros will need their own senders. The chances of the Isspros using the same resistance range of the factory senders is pretty slim.
Postby directinjktn1stgen » Tue Nov 05, 2013 5:21 pm
Good point ! Didnt think about that. Thanks, it was just an idea but i believe itll remain an idea and never happen 8)
Jeffery
directinjktn1stgen
Postby ellis93 » Tue Nov 05, 2013 5:23 pm
What Pete said.....but the fuel sender. You'll need to make sure you buy a gauge made to read for dodge sending units.
Postby PToombs » Tue Nov 05, 2013 5:53 pm
Did you see the thread on the Explorer with the Cummins in it? He has a complete digital dash in it, looks pretty nice.
Postby directinjktn1stgen » Wed Nov 06, 2013 4:51 pm
i did not ! Is that on here or DTR ?
Jeffery
directinjktn1stgen
Postby PToombs » Wed Nov 06, 2013 6:14 pm
Postby Mckinney » Tue Dec 10, 2013 3:16 am
I've been wanting to do this too. Pricey but it sure would beat my cracked and bouncing dash that I'm trying to run now. Maybe a stupid question but when you purchase say a temp gauge from Isspro is it common for it to come with the sender?
Mckinney
Postby TheSilverBullet » Mon Jan 13, 2014 12:56 pm
All isspros come with senders. I put 6 ev2 in my 98 at $750. Very pricey for a first gen IMO.
Brownie-1990 w250 straight six standard transmission 445k odometer quit in 02 lol
The Silver Bullet-1998 qcsb 12v twins and a 6 speed
Blue bear- 2001 3500 pee pumped 24
TheSilverBullet
Postby CumminsPower59 » Tue Jan 14, 2014 4:24 pm
Isspro's aren't cheap, but they are nice. I spent $600 on the four that are in my 91...
Postby jdiesel_us » Thu May 29, 2014 1:05 pm
I agree I had just the usual 3 in my 04 but I never had a single issue with them unlike all the autometers my buddies had.
jdiesel_us
Postby diesel freak01 » Thu May 29, 2014 7:22 pm
I will throw my two cents in here. I am buying a performax setup from isspro. It's a data logger and gauge setup. Gonna be a bit pricey but about 1/4 the price of a different data logger. This is for the pulling tractor btw not the truck. Will be doing some testing on the tach and tach logger they are developing. Everything comes with senders and this setup is computer controlled with multiplexing.
1993 d350 ctd drw 2wd auto
diesel freak01
