Truck died
Re: Truck died
Postby dazedandconfused » Mon Dec 09, 2013 6:18 pm
If its the same as mine it's the main power feed into the cab. You loose it you loose almost everything.
Re: Truck died
Postby Tacoclaw » Mon Dec 09, 2013 6:20 pm
Huh. Who knows, maybe I'm reading the diagram wrong. :?
Re: Truck died
Postby (92)cummins » Mon Dec 09, 2013 6:52 pm
the only thing that ended up still working was the power windows and lights, ill try pulling all the fuses except ignition and see if it changes, once the wind and snow picked up I lost all ambition for being outside tonight
92 w350 srw flatbed
1985 D350 crew cab diesel conversion in progress
79 w200 power wagon
93 D350 drw 5spd getrag 4 door donor
90 D350 auto(fried) flatbed
93 D250 auto
(92)cummins
Re: Truck died
Postby (92)cummins » Mon Dec 09, 2013 6:53 pm
that wire ended up being part of the run circuit
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: Truck died
Postby PToombs » Tue Dec 10, 2013 5:56 pm
So you found a bad wire in the run circuit?
Re: Truck died
Postby (92)cummins » Tue Dec 10, 2013 8:10 pm
all it took was fondling the fss wires accidentally and it fixed itself, there was a small rub though part on one of the wires
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: Truck died
Postby PToombs » Wed Dec 11, 2013 6:28 pm
Good, glad you found it. 8) And the other guys on here tell me all the time that fondling it is a bad thing! :lol:
Re: Truck died
Postby (92)cummins » Wed Dec 11, 2013 7:06 pm
o it has its rewards
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: Truck died
Postby Tacoclaw » Thu Dec 12, 2013 3:49 am
Ha!
Re: Truck died
Postby PToombs » Thu Dec 12, 2013 5:31 pm
(92)cummins wrote:o it has its rewards
That's what I said! :mrgreen:
Re: Truck died
Postby (92)cummins » Fri Dec 13, 2013 5:34 pm
Happy days, i got the truck running but now the radio and dome light don't work
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: Truck died
Postby ashleyco » Fri Dec 13, 2013 7:40 pm
You have a wire touching someplace I would say.
ashleyco
Banned
