speedo and odometer not working
Postby jmd4993 » Tue Dec 10, 2013 1:41 pm
speedo and odometer not working fuses are good where do i go from here? thanks
jmd4993
Re: speedo and odometer not working
Postby CumminsPower59 » Tue Dec 10, 2013 3:41 pm
Check the VSS (vehicle speed sensor), the ratio box, and the wiring to it all. It is located on the back side of the transfer case at the rear output...
Postby Fred Average » Thu Mar 27, 2014 10:20 am
Hi,I'm having the EXACT same issues.
Can you please tell me where the VSS (?) unit is located on a 1992 2WD D250,360
with an Automatic Trans?
And exactly how to diagnose & repair it?
Also if you can help me with a new part replacement source?
Preferably NOS OEM?
Does Chrysler MOPAR Dodge offer OR MAKE new parts any longer for 1st. Generation Trucks????
Know where I can buy a original 1992 D250 Truck Owners Manual?
Thank You.
Fred Average
Postby CumminsPower59 » Sun Mar 30, 2014 7:27 pm
You need a Factory Service Manual. Geno's garage, eBay, various other places have them. It tells you how to do just about everything on your truck.
