HID install help!!!
HID install help!!!
Postby jscott1546 » Fri Feb 07, 2014 4:19 pm
I recent bought a set of hids and projector housings for my 93 d250 but the housings and just slightly to big to fit I was wondering what do I need to cut out to make them fit?? Any advice I'd really appreciate it
jscott1546
Re: HID install help!!!
Postby tim curran » Sun Feb 09, 2014 6:33 pm
What part doesn't fit. I put truck lite led headlights in mine I had to take a wiz wheel and cut out the back of my head light bucket housings for the electrical plug to fit. And air die grinder should work fine. Mark it with a sharpie first then have at it,
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
