1993 w350 ext cab le power doors question
Postby joshotto94 » Sun Feb 16, 2014 4:22 pm
im converting a truck with power windows and locks and mirrors to a manuel the passenger side harnes has a plug behind the dash however the drivers side does not. Has anyone else done this just curiious what i should do wit this harnes just hang it behind the dash cut it and cover each wire end or what any suggestions would be great thanks you JOSH
joshotto94
Re: 1993 w350 ext cab le power doors question
Postby CumminsPower59 » Sun Feb 16, 2014 6:22 pm
It's a long harness, just tie it up out of the way. No need to go cutting things when that can lead to a big mess down the road. The connector for the window/power mirror/locks/speaker harness is centrally located behind the dash if you must remove the harness. I take it you aren't leaving speakers hooked up in the door? I've considered going the same route, manual windows and locks, but was just going to tie up the connectors out of the way inside the doors so that they won't pose an issue or mess with pulling one harness and running another...
Postby joshotto94 » Sun Feb 16, 2014 7:04 pm
coll thanks for the info just wanted to make sure there was no specail trick or ways around thank you JOSH
joshotto94
