Not turning over
Not turning over
Postby mhuppertz » Mon Feb 17, 2014 11:44 am
Replaced the starter relay and the ignition switch, clutch switch soldered. Starts again after sitting.
Ideas?
mhuppertz
Re: Not turning over
Postby RCCUMMINS89 » Mon Feb 17, 2014 12:49 pm
So it won't start until it has sat a while... sounds like the starter itself.
Postby CumminsPower59 » Mon Feb 17, 2014 12:56 pm
Heat soak? The el-cheapo Chinese piece of crap starter I got from Nixon does the same thing after cranking on it for a little bit, let it cool for ten-fifteen minutes and its good for another 30 seconds :roll:
Postby RCCUMMINS89 » Mon Feb 17, 2014 1:11 pm
When the electric motor itself (the windings) wear out... they don't conduct electricity as well when hot. Meaning the starter won't work when driving around after a while. It'll usually seem like you have a dead battery..... let it sit for a while and it'll work normal again.
Postby mhuppertz » Mon Feb 17, 2014 1:27 pm
Everything that is supposed happen does when I turn the key, except there zero sound from the starter solenoid, like when you forget to push in the clutch before you try to start it. I
mhuppertz
Postby dazedandconfused » Mon Feb 17, 2014 1:37 pm
Next time it does it tap on the starter with something. Mine did this when the started died.
Postby doc187 » Tue May 13, 2014 5:35 pm
Mine did the same thing but it was the starter relay which you've already changed.
doc187
Postby BILTIT » Wed May 14, 2014 7:13 am
Have you jumpered the clutch safety switch to verify that's not it?
Derek B.
BILTIT
Postby DodgeFreak » Wed May 14, 2014 9:51 am
[quote="mhuppertz"] clutch switch solderedquote]
I took that as it being jumped.
Postby mhuppertz » Wed May 14, 2014 11:03 am
It was the contacts. Put in a new one and will rebuild the original one with a contact kit. It lasted 400,000 miles!
mhuppertz
