When I got my truck, my brake pedal rested about 4'' above the clutch, we looked under, and there was a nasty tack weld holding a stop if you could call it that. And a spring, we took the spring out so I wouldn't have to knee the steering wheel when I hit the brakes. I tried the hazards a few days ago and they didnt work so I hit the button again, yesterday i hit the button without knowing it, and my turn signals wouldn't work. I went to a buddies place and we tried to address this, and my cruise not working. I tore into the column to see if any wires for the cruise were broken and I couldn't see any. When I got it back together Daniel hit the hazard button and then moved my turn signal and what do ya know, it works. Cruise still doesn't, I think I am going to run toggle switches. Is there any way to make resume and set work on one switch? My brake lights are now on all the time. I have to hit my hazard button when i shut the truck off to get my brake lights to turn off. Hopefully its an obvious easy fix for my brake lights. Any suggestions on that or cruise?
Thanks, Ryker
