Way to by pass
Way to by pass
Postby 92cummins89 » Fri Jul 18, 2014 9:14 pm
On these dodge u have the piece tht sits over push rod for the clutch wondering if there's a way to by pass it like if I wired it to a push button or switch
92cummins89
Re: Way to by pass
Postby PToombs » Sat Jul 19, 2014 6:07 pm
You mean the neutral safety switch for the clutch? If so, yes, you can wire it to a switch. You can just jumper across it, but it's dangerous if someone else drives the truck, and usually not recommended.
Re: Way to by pass
Postby 92cummins89 » Sat Jul 19, 2014 8:58 pm
I'll b the only one driving it, ima put a push button on it so either way ull have I have it engaged to start
Thanks tho
92cummins89
