shackwrrr wrote:The electronic servo style on gm's is standalone controller that works independently of any computers. Only requires power, ground, vss, brake, and the 3 switches(set,resume,cancel). The switches only require a 12v feed and when pressed just momentarily send 12v to the box to send a signal. The upside to this system is no vacuum required. Many aftermarket switches are compatable with the gm unit.
RumbleFish wrote:Whe youre at it, grab the control stalk. PO of my truck added this instead of the steering wheel controls. Take that, clockspring!
