Tach problems
Tach problems
Postby t_ruffcorn » Wed Feb 11, 2015 2:45 pm
Hello! Finally got around to putting my tach in got everything installed and tested everything before I buttoned it all up and It will only read on the tach at about 2500 rpm and up and, Isspro 8503 tach and isspro harness also have a fluidampr on the truck. Anyone have any ideas?
1993 w250 280k, 5 speed, 6x13 @80lpm, BD pin, 63/68/.80, 4200 gov, fluidampr, studs, springs, pushrods, 182/214 hamilton, W/M, steedspeed, PS I/C
t_ruffcorn
Re: Tach problems
Postby thrashingcows » Thu Feb 12, 2015 10:23 pm
Could be a bad CPS, or mis-adjusted one? The signal to the tach comes off the CPS....so I would think this might be your issue?
thrashingcows
Re: Tach problems
Postby dr_funk » Thu May 07, 2015 7:32 pm
Is the gap set correctly on the crank sensor?
dr_funk
Re: Tach problems
Postby dr_funk » Thu May 07, 2015 7:35 pm
I have an isspro on mine and it drops out when the truck idles rough in the cold. I believe its the vibration that throws off the readings. Revving it up smooths it out and it reads properly.
I forget what the gap is supposed to be on that magnetic sensor, but its very slim.
dr_funk
Re: Tach problems
Postby dr_funk » Thu May 07, 2015 7:36 pm
Did you install the magnets on the outermost edge of the fluidampr, or down in the gaps?
dr_funk
