No crank but has power
Postby countrymoparguy » Mon Feb 16, 2015 1:43 pm
So this is my first post on here, I tried searching for my answer but couldn't find anything.
I have a 93 d250 5 speed. Every once in awhile when try to start truck, turn the key and nothing happens. Almost like battery is removed, but all the lights are on and everything works. Turn key a few times and then it'll start up and runs fine. I have a ignition switch being weird or what do you guys think? Thanks!
countrymoparguy
Re: No crank but has power
Postby BC847 » Mon Feb 16, 2015 3:55 pm
Is the neutral/clutch safety thingy switch sure? (I've got an automatic trans but . . . .. ;))
And welcome to our forums. :)
Postby dazedandconfused » Mon Feb 16, 2015 5:56 pm
It could be a few things. It could be the clutch safety switch as BC stated or starter.
Postby dr_funk » Wed May 06, 2015 6:42 pm
Whack on the starter with something heavy and metallic when it refuses to start.
dr_funk
