fuse link replace with fuses
Postby 93cummins89 » Sat May 09, 2015 8:26 am
once again i call on the help of the diesel people. I'm rewiring my d250(as well all know) but iv come to the point of wiring my main batt + into a fuse block and i need to know what size(amp) fuses to place with what used to be fuse link wire....basically turning fuse links into fuses in a block i.e what size fuse should be used with the two power wires that go to the key? once again many thanks for any info i can get.
93cummins89
Re: fuse link replace with fuses
Postby thrashingcows » Sat May 09, 2015 8:38 am
Do some searching here on the 1stGen, and over on the DTR and CF...there are a few threads on these boards that discuss this.
I have not go to to that point yet on my truck, so i have paid little attention to the threads. But I know the grid heaters require 120amp fuses.
thrashingcows
Postby 93cummins89 » Sat May 09, 2015 8:46 am
thanks. my wires look like spaghetti noodles right now but im down to the end of my vacation so it will have to stay like that till the weekends..idk how im going to push button my grids iv been looking and looking. iv redont my wiring 3 times the week and still ready to kick my self in the butt for even starting this mess.
93cummins89
Postby burnt_servo » Sat May 09, 2015 10:51 pm
you can buy fuselink wire to replace the old fuselinks .
I had a old ramcharger with really messed up wiring that I replaced the fuselinks with automotive circuit breakers . they would trip out , then when cool down they would automatically reset .
they looked something like this ,
http://www.delcity.net/store/Auto-Reset ... t/p_198669
'93 w250 .... stock ...
burnt_servo
Postby 93cummins89 » Sun May 10, 2015 7:31 am
Kool thanks. I ran my B+ to a fuse block and jumped my big 6bk alt wire off of that. Then my two key hots from the fuses and everything else that takes B+ power
93cummins89
