ECM delete to do list questions
Postby ofelas » Sat May 23, 2015 5:29 am
Hi, on a 91.5 auto 4x4, if I want to do an ECM delete -
1/ Grid heaters - momentary on pushbutton switch - blue wires from heater relays grounded via the switch
2/ TPS - shouldn't make a difference as all it does it set the 3rd to 4th shift point
3/ OD - red wire off the OD solenoid grounded through a 2-pin toggle switch
4/ Speedo - blue wire off the VSS grounded to chassis
5/ Rear ABS - not affected if I unplug the module
6/ Charging - not affected, as 91.5 is regulated externally
7/ AC & cruise - don't have these on my truck
8/ KSB - not sure what the will affect
9/ Fuel heater & water in sensor - use the Cummins delete nipple and go with an integral drain Fleetguard FS1221 or similar)
10/ The FSO shouldn't be affected
The coolant temp switch, trans temp switch and air temp switch can be left connected as they are now redundant
With the harness unplugged at the ECM, the truck starts, runs & turns off just fine, except that the grid heaters and OD don't get a closed ground circuit.
Anything else Im missing?
R12 = liquid bilit
ofelas
Re: ECM delete to do list questions
Postby 93cummins89 » Wed Jun 17, 2015 2:54 pm
I seen a bunch of places sell a TPS delete kit
93cummins89
Postby Philip » Tue Jun 23, 2015 5:19 am
93cummins89 wrote:I seen a bunch of places sell a TPS delete kit
He is wanting to garbage up his wiring harness. A TPS delete kit means nothing when he removes the PCM.
Postby 93cummins89 » Tue Jun 23, 2015 6:11 pm
i mean a potentiometer
http://www.dnrcustoms.com/store/p46/1st ... 2v%2A.html
like this one should work with out the pcm i think
93cummins89
Postby Philip » Wed Jun 24, 2015 5:01 pm
93cummins89 wrote:i mean a potentiometer
Without a PCM it will not work. The PCM grounds the wire to the OD solenoid. The pot or TPS sends a variable voltage signal to the PCM to tell it throttle position. The PCM uses that info and the speed reading to determine if OD is needed. So with no PCM there is no need for the TPS or the delete kit for it.
To engage OD you provide power to one solenoid wire. When ever the other wire is grounded. OD is engaged. Without a PCM you have to provide the ground for OD. A TPS or delete kit will not do the job.
Postby 93cummins89 » Wed Jun 24, 2015 6:08 pm
oh ok i stand corrected
93cummins89
Postby ofelas » Sat Jun 27, 2015 3:25 pm
"Garbage up" ? Seriously? LOL.
A couple jumper wires, no cutting or splicing.
Less impact than adding fog lamps.
R12 = liquid bilit
ofelas
Postby Philip » Sun Jun 28, 2015 1:09 pm
Every person has an opinion. You have yours and I have mine.
If I walked up to buy your truck. When I noticed every thing removed or by passed. I would take at least 2K off what ever you wanted.
Its your truck do what you want.
Postby ofelas » Sun Jun 28, 2015 2:19 pm
You are missing the point entirely. There is nothing missing, spliced or cut.
Jumping 2 wires for the OD & speedo is less "garbaging" than say, putting in a 4" exhaust or HX40 or airbags.
We all do what we have to do to get max enjoyment & utility from our vehicles.
My vehicles are generally not for sale, but if one was, resale value is the least of my worries.
If you send me up a 91.5 auto PCM for the price of shipping, I"ll add $2k to the price if I sell my truck to you ;-)
R12 = liquid bilit
ofelas
Postby 93cummins89 » Mon Jul 06, 2015 1:14 pm
a 1 wire alternator so you can get rid of that voltage regulator
93cummins89
Postby initial12003 » Thu Sep 03, 2015 1:53 pm
So the blue wire off of the vss grounded to chassis will make my speedo work once more
initial12003
