push button start
push button start
Postby 93cummins89 » Tue Oct 13, 2015 6:24 pm
im wanting to install a push button start and was wondering if i need the starter relay or if its ok to just do with out it. also anything else i may need?
93cummins89
Re: push button start
Postby CumminsPower59 » Wed Oct 14, 2015 7:15 am
Why? Is the ignition switch bad?
Postby 93cummins89 » Fri Oct 16, 2015 6:55 am
no the key and switch are fine just going for something different..got to rewire the whole truck any way..picking up my painless kit from jegs today
93cummins89
Postby PToombs » Fri Oct 16, 2015 4:38 pm
A relay works best, then you have full voltage going to the pull in coil on the starter and it's not going thru the push button to cook it.
Postby 93cummins89 » Fri Oct 16, 2015 5:20 pm
Ok thanks
93cummins89
Postby cougar » Sun Oct 18, 2015 9:30 am
There are push buttons rated for and made for starters. However, a small push button, or momentary toggle switch to a relay can be hidden for an anti theft deterrent.
01 2500 "the work truck".
cougar
Postby 93cummins89 » Sun Oct 18, 2015 10:06 am
I want set it up kinda like a race car with switches that control the main power like a key then a few accessory switches and the start button
93cummins89
