Battery opinions
Re: Battery opinions
Postby edeus » Mon Feb 01, 2016 8:26 am
Thanks, I take that as compliment. No I do not have 5 speed, I am too lazy for stick, love my 727
W250 -1989
edeus
Postby spencerdiesel » Wed Feb 24, 2016 7:41 am
How many volts is our voltage regulator? Is it above 14.1?
Fuel: THD 12 psi piston pump, THD fuel pin, 366 spring, fuel screw 1.75 turn, timing bumped 3/32"
Muffler delete
spencerdiesel
Postby CumminsPower59 » Wed Feb 24, 2016 8:35 am
It's around 14...ish. Why?
Postby spencerdiesel » Wed Feb 24, 2016 10:05 am
Just so I know for the next battery I get. Glass mats and gel types don't like higher voltage like the lead acids
I've heard the concensus that 14.1 is the limit for the gels
Muffler delete
spencerdiesel
Postby CumminsPower59 » Thu Feb 25, 2016 6:06 am
Here say. Mine runs 14+ and those Optima's I have are quite old compared to lead-acids...one is almost nine years old and the other is older than that. They have been through hell, but have served very well.
In my honest opinion, any AGM battery is a good choice.
Postby spencerdiesel » Thu Feb 25, 2016 6:44 pm
Thanks sir.
Muffler delete
spencerdiesel
Postby Philip » Mon Feb 29, 2016 5:41 pm
Did you have to add a extra leaf into the left front spring to set the truck back to level? :lol:
Postby edeus » Tue Mar 01, 2016 11:03 am
Personally I took one leaf off from both fronts, now I can imagine my front suspension moving even bit.
Really would like to know where those springs are originally meant to be installed, no dodge for sure.
W250 -1989
edeus
Postby ofelas » Sun Apr 10, 2016 3:37 am
LOL at the springs :-)
Heres my setup, fed by an external VR and a 240amp alternator (120 amps at 900rpm)
R12 = liquid bilit
ofelas
