91 - 93 odometer/speedometer correlation
Postby spencerdiesel » Sat Jan 16, 2016 8:51 am
I've been to several threads on fixing the non working odo, but haven't seen quite what I was looking for. My odometer worked on and off for about a year, then 4 months ago it completely stopped.
Also, from time to time (maybe twice a month) my speedometer does not move. It has ONLY happened once the truck has been stopped/shut off and I start it again. Most times after I get over about 20, the needle jumps up and works like it should. On a few occasions, I drove for a few miles @ 50 mph and it didn't work until 5 miles down the road. It's hit and miss.
So what I was wondering was; will the new nylon gears fix my odometer issue as well as my speedometer? Or only fix the odometer?
H1C/18
Fuel: THD 12 psi piston pump, THD fuel pin, 366 spring, fuel screw bottomed @ 3 turns, timing to the head/ >1/4”
Muffler delete
spencerdiesel
Re: 91 - 93 odometer/speedometer correlation
Postby Philip » Sat Jan 16, 2016 9:43 pm
Gears will only fix the ODO. The speedo has other issues.
does the truck have CC and does it work?
Postby spencerdiesel » Sun Jan 17, 2016 7:34 pm
Ok thanks. CC.......I feel like I should know what that is
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Mon Jan 18, 2016 5:17 pm
(cruise control)
Postby spencerdiesel » Tue Jan 19, 2016 9:38 am
Thanks :D it has CC but it does not work
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Tue Jan 19, 2016 5:27 pm
If cruise doesn't work either then it's more likely a VSS problem.
Postby spencerdiesel » Tue Jan 19, 2016 7:22 pm
Thanks, I'll check into it a bit
H1C/18
Muffler delete
spencerdiesel
Postby spencerdiesel » Mon Feb 15, 2016 5:13 pm
Read a great thread with info from Mark Nixon and it helped my understanding (painfully weak knowledge in electrical). Where could a correct VSS be found these days? Any OE stuff floating or has it all been gotten?
Speedometer is starting to act up more, when it works it works correct. But today it would quit when I took off from a stop, and then after a min or so would jump up and work fine. Did it three times, when before it would ONLY not work after the truck started, then worked correct until shutting the truck off.
Another question, If my speedometer quit completely but I put new gears in for the odo, would the odo work?
H1C/18
Muffler delete
spencerdiesel
Postby dpuckett » Thu Jun 29, 2017 9:12 pm
Before you buy odometer gears, make sure you have the 90-92 style speedometer. I had a late 92 (June build, IIRC) with a CPL 1579 engine that had the 93 style odometer- the digits were closer together.
Postby spencerdiesel » Sun Jul 02, 2017 8:45 am
Thanks dpuckett, my odo numbers are spaced a little more
H1C/18
Muffler delete
spencerdiesel
