Blinker fluid maybe?
Postby 92cummins89 » Fri Jan 29, 2016 5:35 pm
My blinkers aren't workin on my 92 got all my running lights workin but no blinkers is there a relay for them or ? I'm kinda lost
92cummins89
Re: Blinker fluid maybe?
Postby PToombs » Sat Jan 30, 2016 5:33 pm
There should be a flasher in the fuse box, round unit, you can't miss it. 2 actually, 1 for the signals and 1 for the 4 ways. You can swap them to test
Postby 92cummins89 » Mon Feb 01, 2016 10:08 pm
Just replaced both of them an everything works
Just gotta figure out my reverse lights now
92cummins89
Postby PToombs » Tue Feb 02, 2016 5:32 pm
No flasher for that one buddy. ;)
Postby 92cummins89 » Tue Feb 02, 2016 10:28 pm
Yea crawled under the truck an found it lol was hidin from when I pulled the trans
Have to more wires tht are cut along side the trans an t case wires there is a black wire with two blue lines on it an orangeish color with a faded white line any idea wat the go to?
I'm guessing fuel gauge maybe ?
Or speedo?
92cummins89
